Marking an area on a face
I need some help. I'm sure this must be possible...
I have a face which I would like to mark up with different sub-areas (which I want to name). For example, say I have a curved face that I want to define an area (say from u=0.25 to u=0.5 and from v=0.35 to v=0.6). I would like to name this "sub face" something like "yellow".
I'm sure this can be done - but I don't have a lot of CAD experience.
Help much appreciated!
RE: Marking an area on a face
Steve u could subdivide the face by projecting curves on to it. Then either change the colour of the face in object display or label the faces through drafting.
(sorry a bit late I imagine)
Or you could extract the isoparametric curves in both U & V directions & just use those to Edit Face -> Subdivide Face.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Hi, thanks for your help.
In the end, I have a method that seems to work okay. First I get the points in u-v space on the face. I next join those points by a striaght line, then project that line onto the face in question. When I have a closed line I join the lines together then subdivide the face.
but thanks for your help.
Steve
If steve won't give hodgo2 a star, then I will.  Pretty much what he advised to begin with, other than the point extracting.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Sorry, forgot to award star (and for the delayed repsonse to the tips - I've been on holiday for a few weeks)
Thanks to hodgo for tip. I got the same route myself some time ago and have it all coded in ug_open, but still not excuse for forgetting the star - I guess you could put it sown to holiday return rustiness!
Was just kidding, Steve.
Welcome back, BTW!
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
