Centrifugal blower for high pressure air
Hi friends,
I want to select a centrifugal blower for air at 36 atm. pr. The voulmatric flow rate for this application is about 55 cfm and pr. drop in pipe line for this flow rate is about 18".
The problem is I don't know how the volumatic flow rate of a particular centrifugal blower changes with gas or fluid density.This is required to find out the possibility of using a redily available blower with suitable motor.
Any suggestions??
Any suggestions??
"Knowledge is power"
