Sleeve bearings - Bump washer
I have seen specification for motors with sleeve bearings which states the rotor end play shall be 12 mm ( for example ).And the clearance shall be exclusive of the bump washer. Bump washers shall carry no load in normal operation. My question is what is a "bump washer"
RE: Sleeve bearings - Bump washer
