Generation of IMPACT FACTOR of Bridge Standard Loading
Hi friends,
I am working on generating a standard bridge loading for our country. I have established standard design vehicles by analysing the traffic axel load data of our country. Now I want to establish a relation for computing IMPACT FACTOR on bridges.
So, can anybody help me by suggesting me the method of calculating IMPACT FACTOR.....?
RE: Generation of IMPACT FACTOR of Bridge Standard Loading
Have you tried the Bridge Engineering forum?
Stephen A
The governing bridge code (AASHTO) here in the USA uses the following formula -
I = 50/(L+125) where L is equal to the span length under investigation.  I is limited to 0.3.
For regions of the span where there is continuity over the supports, the L is the average of the adjacent spans.
This has served us well over the years since the code's inception.
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Just to be clear shakildor, Qshake noted a percentage of LL, not a factor.  The factor would be limited to 1.3 ......  I would hate for your code to specifiy a .3 Impact Factor.
