Zero Thickness
Zero Thickness
Is there a way to have zero thickness in SW 2004? I dont want to disjoint anything, I might want to put a c'bore with 3/8 dia 3/16 away from the edge for example. I know i can lie to it, but is there is an option for that? Thanks
RE: Zero Thickness
Mostly, I'm curious as to why you would put such a feature into your design. That thin web will be nothing but trouble. If your c'bore is that close to an edge, perhaps you ought to mill it from the side.
http://www.EsoxRepublic.com
RE: Zero Thickness
RE: Zero Thickness
RE: Zero Thickness
RE: Zero Thickness
