Looking for spare 3000 HP wound rotor motor
Hi all,
         am searching the world for a spare Mitsubishi 3000HP wound rotor motor- 3300 volts, 740 rpm with a frame size of 1000. Can any one offer any assistance at all in regards to this??
Thank you. DaveJG
RE: Looking for spare 3000 HP wound rotor motor
http://www.surplusrecord.com/sre/023972a.htm
Quite a few near matches there but none match your voltage.
HP   RPM
3000 713 Brush, Fr.NWA630/42, 4160 V.
3000 720 Gen.Elec., shredder duty w/controls,2300/4160 V.
3500 720 Gen.Elec., shredder duty w/controls,2300/4160 V.
4000 715 Westinghouse, DP, 2300/4160/6600 V. (2)
5000 720 West.,Fr.10-85-27,DP,2300/4160/6600/13200 V. (2)
Maybe select a 4000hp and connect in 4kv configuration. Operate at reduced voltage of 3kv and derate 75% to 3000hp.  You'll have to call to check info not listed framesize etc.
Please send me complete data, and I will see about quoting new or used. Send data to vectormotors@yahoo.com.
Farkle
Please give me appliction, eg. rock crusher, etc.  Also
need drawings and nameplate data, and secondary circuit
data, and all data pertaining to particular motor that
you can glean.  Send to vectormotors@yahoo.com.
