CamWorks and hole wizard features
Our machine shop uses Camworks for our parts designed in SolidWorks. When countersink or counterbored features are put in using the hole wizard, CamWorks does not automatically recognize the csink or cbore portion. If the same feature is put in as a cut extrude vs. cut revolve, then everything works fine. Anyone else come across this?
As a designer, I use the hole wizard as a convenient way to save time, but it ends up taking our programmer extra time to manually program those holes.
RE: CamWorks and hole wizard features
