BLOCKS WON'T PLOT
BLOCKS WON'T PLOT
received a drawing from a vendor and none of the blocks in the drawing will plot, they all show up in the drawing, and are not on a no plot layer. any suggestions? (other than exploding all of the blocks).
RE: BLOCKS WON'T PLOT
If the entities in a block are on a no plot layer (or defpoints) when the block is created, they will stay on the layer, even if you change the layer the block itself is on. If the block is created with the objects on layer "0" then it will inherit the properties of whateve layer is gets placed on.
I would suggest expoding one to find out what is was created on.
designer gooroo
catia v5
unigraphics nx
pro-e wildfire
ideas v10
autocad 2004
