[b] 'UNDO' function from within VBscript or VBA[/b]
I'm very new at Catia VB programming and have written a program to create normal lines to through points of an open body and normal to a face. When the first line is created the user is prompt to reverse direction YES/NO. If yes, I want to 'UNDO' the created first line, change the length variable and then create the first and subsequent lines in the opposite direction. I've got it all except the 'UNDO' for the first line.
This is the loop:
For i = 1 to countA
    Set reference2 = Part1.CreateReferenceFromObject(hybridShapes1.Item(i))
    Set hybridShapeLineNormal1 = hybridShapeFactory1.AddNewLineNormal(reference1, reference2, Length, 0, False)
    hybridBody2.AppendHybridShape hybridShapeLineNormal
If ( i = 1 ) then
    part1.Update
    response = msgbox ("Do you want to Flip?",4)
    If (response = 6) then
        Length=-25.4
        >>>undo goes here<<<
        msgbox "reversed direction"
        i=0
    End if
End if
next
RE: [b] 'UNDO' function from within VBscript or VBA[/b]
Hi, try:
CATIA.StartCommand ("Undo")
   The 'CATIA.StartCommand ("Undo")' seems to go back too far. Within the program, I select a Body of points, select a face, create an Open Body for new lines, create a line through the first point normal the face, and prompt for direction. If the 'Undo' command is used here, it removes the Open Body for the normal lines as well as the first point. All I wanted to do is remove the first created line......
   Since the request, I '.add' the line to a selection and delete it. Works fine.
   I still would like to know if there is a way to 'UNDO' only the last created element.
If you've got a reference to the last created object (hybridShapeLineNormal1) , add it to a selection and then delete the object using the selection.
