Short Circuit Ratio Calculation
Not familiar with short circuit ratio (X/R) of synchronous generator calculation.
Given generator reactances (Xd, X'd, X''d, ....), time constants, stator/rotor resistance, etc.
How would on compute the short circuit ratio ? (if it is possible with the above info.)
RE: Short Circuit Ratio Calculation
The short circuit ratio (SCr) is different than the X/R ratio. For generator applications, the SC ratio is the reciprocal of the synchronous reactance Xs
SCr = 1/Xs.
Please note that for SC purposes, the sub-transient reactance( X”d) should be used in the calc.
I hope this could help.
Example data sheet,
Xd = 2.6265 p.u
Xd = 1.6625 ohms
X''d = 0.1414 p.u
X''d = 0.0895 ohms
short circuit ratio = 0.4947
From the info. on the generator data sheets (i.e. Gen. resistances (stator, field), reactances, time constants), can I determine the X/R ratio ?
Thanks again
Field Amps for producing rated stator voltage on open circuit/Field Amps for producing rated stator current on three phase short circuit
For 2 pole turbogenerators, it is about 0.5 and for salient pole machines, it varies from 0.9 to 1.1
MG Say (Performance and Design of AC machines) says that the unsaturated reactance is not affected by the operating conditions and hence quoted in the data sheets and is higher than 1/SCR. SCR is defined as reciprocal of synchronous reactance (saturated).
It appears the problem is you are looking at unsaturated reactance and the SCR in the datasheets of generator manufacturer and that explains the discrepancy you are finding. If you can obtain the saturated reactance value from the vendor, it should clear the air.
(the reactance values shall be in PU)
Trust the above is helpful.
"The un
The AVR often has a short circuit maintenance facility which increases the excitation to maintain terminal volts under fault conditions in order to allow the protection to operate.
Just looking at the electromagnetic characteristics of the machine will not give you the whole picture.
_______________________________________
Regards -
Colin J Flatters
Consulting Engineer & Project Manager
