hidden edges select; selection sets
Hello! We passed from catia v5r10 to v5r12sp5 and we have some problems: can you help us?
1. In Part Design Mode (3D) Render Style in Shading mode with edges the Hidden edges/poins can't be selected (in order to be use for measuring, Project 3D elements etc.) and only by Using the Preselection Navigator.
2. In Drafting Mode (2D) I can't use Selection Sets Edition... command whith a GeneratedItem for example the circles which result from a generated view of a 3D part with several holes even if "Select a face, edge, axis or vertex" option is enabled. The size of the Set remains 0 and the set is empty.
Jenö
Jenö
RE: hidden edges select; selection sets
