Editing Angles
3
Editing Angles
Editing Angles
I have SW 2000 and I am just starting to learn SW, I have been using AutoCAD 2000I, so all this is very new.
My question is if I sketch a line @ 310 deg and I wanted it to be 320, if I try to edit that, the sketch goes crazy?
RE: Editing Angles
Have you gone through the SolidWorks tutorial? If not then I would suggest you do so. This would make life a lot easy for you in the long run and the time spent is well worth it.
Bradley
RE: Editing Angles
If you change an angle dimension and the sketch goes crazy, it is probably because of a lack of constraints in your sketch.  This would be true for any parametric sketcher (SW, Pro/E, UG, etc.).  If you are an AutoCAD refugee, you may not be used to sketch solving.
Pay attention to the colors in your sketch, as the colors tell the constraint state (default: blue = underconstrained, black = constrained, red = overconstrained).  It helps to make endpoints and centerpoints visible.  See options under "Tools --> Options --> System Options --> Sketch", and check "Display arc centerpoints" and "Display entity points".
Due to illness, the part of The Tick will be played by... The Tick.
http://www.EsoxRepublic.com
RE: Editing Angles
Also...
Brown - Invailid Geometry - This geometry would be geometrically invalid if the sketch were solved.
Pink - Not solved - The sketch geometry cannot determine the position of one or more sketch entities.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
