constant torque V/hz controller code
I am thinking about writting designing a 1 phase 120volt
inverter drive and I was wondering if anyone here had snippets of the code or algorithms that I could use to start. I'll be using the Atmel AVR in AVRBASIC and I generally only use phase control but thought it would be fun to build a real good drive this time. Thanks for your help!
RE: constant torque V/hz controller code
"Venditori de oleum-vipera non vigere excordis populi"
Great question, I am designing a mixer for food materials such as health supplements. The motor everyone but me wanted is a large shaded pole type of motor. I may not be able to use frequency control here. Maybe you know this already?
That said, it would still be far less expensive for you to buy something already made. For instance, many many low cost (under $100) OEM VFDs are available now that will convert 1 phase 120VAC to 3 phase 240VAC variable frequency from 1/16 to 1HP. All you would need to do is change to a 3 phase motor. Easier to reverse too if that is a desired feature in your mixer.
If you insist on sticking to a single phase shaded pole motor, a company called Anacon Systems already makes a PWM drive for them.
Barry1961
I hear you guys; but, I don't know if @ my anticipated volume ~~3,500/year the economics don't commend designing one myself as opposed to relying on a 3rd party. And, while I appreciate the investment a drive manufacture has in his control program, I'm sure I've given away at least the same value commercially in the last month in 'scraps and pieces'.
I do see, in retrospect; however, that I should probably use voltage control alone with torque boost as a small vernier to vc. Thanks on the line to Anacon, I'll look at what they have available and consider buying some of their wares if they fit this. Thanks again!
Best regards
Mark Empson
http://www.lmphotonics.com
Been there. It doesn't work very well. The shorting ring gets more or less useless at low frequency. Torque drops abruptly.
I am surprised that someone wants to do this. There are many better standard methods. And motors.
For small kitchen and bath-room ventilators, we have designed very simple triac controllers that change the motor voltage and utilises the increased slip to control speed. It works quite well because of the quadratic speed/torque relation, but it will not work with a constant torque load like a mixer. Even less so if it is frequency controlled. Torque goes down the sink.
