DC Shunt Heat Dissipation..
Anybody got a table of some sort with a general rule of thumb for heat loss  on DC Shunts. The manufacturer of the ones we've ordered doesnt seem to have got that info!?!?
range 0-100A, 60mV output
cheers guys
RE: DC Shunt Heat Dissipation..
Doesn’t  100A · 0.060V = 6W  still work?
no really because thats electrical power. only a percentage of that would be heat, surely?
Yes, honestly, your shunt is dissipating 6W as heat. A shunt can't perform any mechanical work; what else could it dissipate the energy as?
Your shunt is just a resistor, much the same as an electric fire element or a tungsten lamp. The only difference is that the resistance is very small and the volt-drop is therefore small. Ohm's Law still applies.
P = V * I
or
P = I^2 * R
Both give the same result - 6 watts.
If we learn from our mistakes,
I'm getting a great education!
Sorry about that busbar,
just after your post i spoke to somebody who imformed me the same..
cheers lads
Busbar and ScottyUK are correct, all that power is dissipated as heat.
No problem, JR.  The informal nature of Eng-Tips is handy for that reason.
