Quick question: Looking for word in english.
What terms do you use in english when an engine (typically diesel) overspeeds out of control? This is typical of big diesel truck and generators, when the injectors fail in such a way that the engine accelarates out of control and the only way to shut it down is by cutting the fuel supply. I don't mean the term "overspeed", which covers situations that aren't as grave as the condition I'm describing.
In spanish, particularly here in the Dominican Rep., we refer to such conditions as "desbocar" or "embalar". "Desbocar" is also used for horses. "Embalar" is used less frequently for diesel engines, but quite frequently for turbines.
Please let me know your respective areas of residence, in case there are regional differences. For example, US vs UK, etc.
RE: Quick question: Looking for word in english.
If we learn from our mistakes,
I'm getting a great education!
Runaway connotes that all of the above are not applicable due to whatever reason, and the situation is out of control, and that catastrophic failure is iminent, and that one might want to consider "running".
rmw
Thanks, all.
