cable bridge
cable bridge
In cable_stayed bridge,is it OK to be different numbers of cables on the two sides of a pier? Is it technical?
RE: cable bridge
So a larger question is why would you want to have a different number of cables on each side of the pier? This would appear that the loading was asymmetrical and possibly biased for a certain direction.
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
RE: cable bridge
RE: cable bridge
Secondly, it would best be answered by a member of your design team with a good background in cable-stayed bridges. If you are new to this type of bridge design, this would be a very challanging case to start on and nothing can replace good experience.
Best of Luck
RE: cable bridge
I am looking for good books on cable stayed, suspension, and arch bridge design/construction. Can you guys recommend some? Seems few out there and many out of print.
Koo
RE: cable bridge
I have a nice book by M.S. Troitsky and I know that ASCE has a text on Cable Stay bridges too. The text is by Walther is can be found at this link:
http://www.pubs.asce.org/BOOKdisplay.cgi?9990603
The Troitsky text is dated.
Qshake
RE: cable bridge
Thanks, looks like a good book. Can you check my question for you in the lateral bearing load thread? Thanks.
Koo
