Display solid leader default
I know this must be a simple problem but my drawing dimensions for circles always start as "display with solid leader" as the DEFAULT property setting. I can ctrl pick all the circular dimensions and right click properties to change this but it is time consuming. I hope there is a way to have the default changed.
Also on same thread of discussion when I do ordinate dimensions they always start as "display as chain dimension" and I would like to change that default. This also can be changed with a right click on properties.
DeSimulacra
DeSimulacra
RE: Display solid leader default
Go into your dwg template and under tools->options-> document properties-> dimensions -> leaders ->have a play in here to find possibly what you are looking for.
Hope this helps
Brett
Meantime, can you use ANSI standard? It does not include the "display with solid leader" feature.
Thanks again for the quick help I always receive. Look forward to the day I can return favor(s).
