right click menu
right click menu
right click menu
My right click option has disappeared in ACAD 2003 LD3.  Right click works in windows, and when I open ACAD 2004.  this problem occurred when I loaded a digitizer, which also works only in 2004.  Any suggestions?
RE: right click menu
Go to Tools > Options and then click on the User Preference tab...I hope this helps
Thanks for the reply.  I had been there before, the right-click user preferences are set-up correctly.  This is something to do with the tablet set-up I believe.  Any more suggestions?
Just an update, I am actually using AutoCAD 2002 with LD3, I also have Civil 2004 loaded; both my digitizer and my right-click work fine in Civil 2004, but not in LD3, which the rest of my office is using.  ACAD fails to detect WinTab on setup, but WinTab is loaded.
