Slab Strengthening
Slab Strengthening
I have a slab that is deflecting too much, and i would like to know what kind of action regarding it's repair should i should take.
Thank You
Thank You
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Slab Strengthening
Thank You
Does the floor consist of only this slab and 4 beams surronding it?
What is the function of this slab in the building?
what kind of loads is expected on it?!
if any of the beams are not edge beam you may add negative top reinforcemnt over the beam to connect the slab you have probelm with to anoter slab this will reduce positive moment which cause cracks
you may add steel beams also under this slab and undeflect it using Jacks or something like this till instalion of the beams is done
