Mechanical test
Mechanical test
where can I find the demension and specs of ASTM of tensile and charpy test for AISI 1080 (other than ASTM.org)?
Thank you.
Thank you.
RE: Mechanical test
You should do a search on Charpy V or U or just impact test.
RE: Mechanical test
The Charpy testing standard is ASTM A370. The standard, full-sized specimen is 10mm x 10mm x 55mm. Three specimens are tested at the Min Design Metal Temp. The average of the three must meet the impact criteria. See ASME VIII, UCS-66 and UG-84. There are other rules too.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
RE: Mechanical test
No, the ASTM specs (esp old ones) are not great. But the only way to say that you meet one is have a copy in front of you.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
