Auger Electron Spectroscopy
Does anyone knows what Auger Electron Spectroscopy is?
and where could I find more information regarding this matter?
Thank you.
Thank you.
RE: Auger Electron Spectroscopy
Any good reference on analilitical methods that covers SEM and such should cover Auger.
It is a tricky tool. The atoms don't all come off of the surface with the same efficency and the detection system isn't perfect. There is a lot of data massaging required to get a real profile.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
http://www.phi.com/genf.asp?ID=281
A Google search yields plenty of information.
Cory
Auger Electron Spectroscopy as a technique does not liberate atoms, only electrons (and low energy ones at that). Depth profiling is accomplished by adding another technique, the most popular being ion milling (usually using Ar+ ions).
Cory
