Wind Application to High Mast Lighting
I am investigating a high mast light basket failure. When applying the wind to the lights in the direction that the lights are in a line (spacing 3'oc), are there any good guidlines for taking into account shielding or reducing drag coeficients or do you apply the same wind to each individual light as you would when the wind is in the perpendicular direction?.
RE: Wind Application to High Mast Lighting
I usually take a third off any horizontal member supporting the lights, if they form 360 degrees, that is occupy three sectors.
VOD
