drawing hatch lines
drawing hatch lines
drawing hatch lines
Is there a way to turn off hatch lines in a section view of an assembly in a drawing?
RE: drawing hatch lines
RMB in the hatch area, crosshatch properties, none.
Thanks! I knew the answer would be obvious when I heard it.
It happens...your welcome
New drawing, new section view. Cross hatch properties is not an option when I RMB. Any idea why?
If you are using 2005, the properties are now in a dialog at the LH side of the screen when you LMB the crosshatch area. All the previous controls are still there.
If you aren't using 2005 I don't have any ideas.
