Thermal Actuated Valves
Hi all,
I have an application where I want to control cooling water to a coil through a valve.I want the valve to be operated by the air temperature. When a set point is reached (35 deg C) the valve opens sending cooling water to the coil. Air is forced through the coil cooling it. When the air gets below 35C the valve shuts off. Is there an all in one valve that does this? What are they called? Thermal Acutated Valves or Thermal regulators or different? FYI, I wanted to avoid seperate units and a PLC, etc.
Bill
Bill
RE: Thermal Actuated Valves
Friar Tuck of Sherwood
Look At: www.spenceengineering.com
