FOXBORO SPEC200
FOXBORO SPEC200
FOXBORO SPEC200
Does anyone have the wiring diagrams for the SPEC200 analog controllers model number KIT-E27-ID-SAS-TA? I need the terminal connection diagram.
thanks,
CTG
RE: FOXBORO SPEC200
As I see that you got no answers - Think I can get the information,  but need to make a deep digging for it. (Installed the system 1976, and it was replaced about 20 years ago). Do you still need it?  (I had it in English and in Russian those times). if so, please write here or to:  ilan_a7@yahoo.com
or replace it with new controller....
RE: FOXBORO SPEC200
have you tried foxboro?
RE: FOXBORO SPEC200
Yeah, I could still use the diagams. I could also use the PCB jumper settings and their function. Foxboro was really no help. I talked to them but never got the info they said they were going to fax.
thanks,
ctg
