Tall Slender Circular Concrete Tanks
I have a tall concrete tank (28') with a small diameter (8').  Normally for my tank design I would refernce the PCA "Design of Circular Concrete Tanks Without Prestressing", but in this case by H^2/Dt value is off the charts for calculating my hoop tension.  Is there another good reference that picks up where this one leaves off?
I am running into a similar situation in my seismic calculations as I try to determine the impulsive and convective mass factors.
I think I know what I need to do, but I wanted to some input from you guys.
Thanks in advance,
RE: Tall Slender Circular Concrete Tanks
Forget the charts.  Hoop Tension = Pressure X Radius.
You may wish to check AWWA D100 or API-650 for the seismic factors you need for a tall tank.  They both cover the full range of tank H/D.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
Assuming liquid product? are we?
Thanks Steve, and yes connect2 this would be liquid product.
