Based on Formula, can I show a particular bitmap?
I have a formula which tells me how the forces are arranged on a free body diagram.  Is there a way to force it to display a particular bit map picture.
If I wanted text, I could use an if statement and then specify the resulting text to display. Can I use something similar for an object or a bitmap.
RE: Based on Formula, can I show a particular bitmap?
i am not certain how to do it in a VBA macro, but in a VB6 program you would put an image control box on the form (insert an image control in your EXCEL sheet, set stretch property to true). then, in an if statement, use the LOADPICTURE command....like.....
imagebox1.picture=Loadpicture("C:\myfolder\mypic.bmp")
not sure if you would do an if statement in a cell or by way of a VBA macro.
daveleo
Sub delete()
Here's example code I use in a vessel volume workbook. This has different images depending on head type. I also have a button in which you click to select head type. (Macros are assigned to these buttons)
' Deletes previously inserted pictures
   Sheets("Vessel Volume").Shapes("Picture1").Select
   Selection.delete
End Sub
Sub move()
' Relocates picture to correct location
   Selection.ShapeRange.IncrementLeft 288.75
   Selection.ShapeRange.IncrementTop 81.75
End Sub
Sub resize()
' Resizes picture to correct size
    Selection.ShapeRange.ScaleHeight 0.77, msoFalse, msoScaleFromTopLeft
End Sub
Sub Conical_Insert()
' Inserts Conical head picture
    Call delete
    Sheets("Pictures").Select
    ActiveSheet.Shapes("Conical").Select
    Selection.Copy
    Sheets("Vessel Volume").Select
    Range("A2").Select
    ActiveSheet.Paste
    Selection.Name = "Picture1"
    Call move
    Call resize
    Range("E17").Select
End Sub
Sub Ellipsoidal_Insert()
' Inserts Ellipsoidal head picture
    Call delete
    ActiveSheet.Shapes("Ellipsoidal").Select
    Selection.Copy
    Range("A2").Select
    ActiveSheet.Paste
    Call move
    Call resize
    Range("E17").Select
End Sub
