Proper age hardening time and temperature for aa6082 Al Alloy
What's optimum aging procedure for aa6082 and mechanical properties which will acheive?
RE: Proper age hardening time and temperature for aa6082 Al Alloy
www.alcoa.com/adip/catalog/pdf/Extruded_Alloy_6082.pdf
The Aloca file does not have heat treatment specs.
The other web site is one that I use to track down Aluminum alloy compositions/properties;
http://aluminium.matter.org.uk/aluselect/06_composition_browse.asp
I believe you may have to obtain a copy of the British Standard 6082 or check with the European Aluminium Association to determine specific solution and aging heat treatment specifications for this alloy.
