about seal a shatf under 30 meters sea water
i'm a mechanical engineer who are developing a inner pipe inspection robot, it will work under 30 meters, in sea water. i need to make the shaft of the wheel waterproof, so the sea water don't let enter to the electronical system. the shaft is near 1 cm diamenter.
please help me
please help me
RE: about seal a shatf under 30 meters sea water
1) The entire internal space is nonconductive fluid filled and maintained at outside pressure.
2) The wheels are on external shafts and magnetically coupled to the inside motor shafts using permanent magnets across a non-magnetic barrier..
please tell me more about ...:
"The wheels are on external shafts and magnetically coupled to the inside motor shafts using permanent magnets across a non-magnetic barrier.."
can you tell me about those kind of motors?
Under water at high pressure the plastic barrier might need to be domed so it won't deform under pressure and the magnets appropiatly shaped (the closer the magnets are to each other the stronger they couple). The external shaft might simply be a stainless steel shaft in carbon bearings fully exposed to the sea water (or simple seals to exclude grit).
To get a feel for the magnet couplings you could buy a commercial pump and disassemble it (Graingers-McMasters, etc.)
Jeff
I would like to add one thing to this topic. If you have a oring shaft seal, the weight of the robot onto the shaft may make your oring oval which may cause a leak path. I would try to ensure that the loads are not transferred to the oring sealing area.
Tofflemire
On further thought, if the shaft has 2 o rings with the space between them flooded with oil, this would both lubricate the o rings and provide a barrier to any water leaks.
Or, if the robot has an umbilical cord, incorporate an air line to pressurise the housing. This would keep the water out if the air pressure was greater than the water pressure.
Jeff
I do think you'd be wise to go with a pair of O-rings on the shaft rather than a single. I'm not that the oil between the two O-rings will provide much benefit. More important, I think, would be to lube the O-ring/shaft at the proper mainenance intervals.
Take a gander at the Parker literature for guidance or contact one of their application engineers.
Suggest you consider pressurising the inside to "ambient + a little bit" from a small supply of compressed air. With a reduced pressure differential across the seal, there should be a ower tendency to leak, and what leakage there is will be in the right direction (air out, not water in).
A.
(b.t.w., absolute pessure at 30m is 4 bar, not 3)
Look at rotary seals
http://www.kalsi.com/index.htm
These people also have bearing materials as well as seals
http://www.busakshamban.us/
I will go with the assumptions presented to date and assume a rotary seal. Please note there are other seal types, static, dynamic (reciprocating, pneumatic floating and rotary) as well as face seal alternatives. Each of these introduces the variance of elastomer compression, that is, squeeze. The squeeze also depends on the diameter of the o-ring specified. Commercial available types are 0.070, 0.103, 0.139, 0.210 and 0.275 diameters which coincide to 000, 100, 200, 300 and 400 series o-rings respectively.
For the shaft size specified, 1.0 cm or 0.394 inches, I would use a 000-045 Series o-ring because machining the male o-ring groove would weaken the shaft somewhat. It is more cost effective to machine a male groove rather than female because the machinist has much more control on the external profile. In the elastomer series selected for rotary application, the squeeze is no greater than 11% for 200-1500 RPMs. Thus the gland specifications are 0.262/0.260 diameter X 0.075/0.079 inch wide; this gives a mid range squeeze, approximately 5.5%. Your mating piece must therefore be drilled and reamed 0.396/0.398 diamter with 63 Ra finish. A number 2-010 o-ring (0.239 ID X 0.070 CS diameter) should be used.
Now check the elastomer stretch, typically 2% to 3%. I get 9.6% which is really, really high for the application. Expect o-ring necking to lessen your squeeze, but you are in no-mans land since the a 2-011 o-ring is too large for the groove specified. A quick review for a female groove cut into the cylinder of the mating piece gives no additional advantages. Similarly, going to a 100 Series o-ring would only weaken the shaft in male groove design or present manufacturing issues with female groove design.
Finally look to lessen elastomer stretch by lessing the sqeeze. You're talking 30m of seawater, I would argue not much pressure and the o-ring selected is good for 1500 psi without the necessity to resort to backup rings. Going to a 2% squeeze would imply a male groove specification of 0.259/0.257 dia X 0.075/0.079 inch wide, the stretch drops to 8.4%. This is still on the high side, but professionally speaking, I've used specified worse with experiencing problems. For the sake of discussion go with it using 2-010 o-ring.
Now select material, dependent on fluid application and temperature only. Nitrile is acceptable, I'm a big fan of a flurocarbon alternative like Viton. The typical durometer or rubber hardness is 70.
In summary, cut a 0.259/0.257 diamter male groove, 0.075/0.79 inches long into the shaft and give 0.02R fillets in the groove, 0.005/0.007R shoulder fillets. The surface finish is 63 Ra. Drill and ream the cylinder or mating piece to the shaft, 0.396/0.398 inch diamter with interior finish 63 Ra. Specifiy a 2-010 o-ring, Parker-Hannifin Corporation made of Viton, durometer 70.
...and there you have it...
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
As an update to the excessive stretch issue, I would hot splice a bastard o-ring from 0.070 inch primer cord. That way, you get exactly the right stretch, between 2% and 3% while maintaining squeeze. Unfortunately for the o-ring gland specified, there is no imperial commercially available o-ring that will meet the recommended specifications.
Not a big deal, I have hot spliced many specialty o-ring(s). Use a certified manufacturer and be sure to vulcanize the primer cord at the joint! I haven't worked out the exact o-ring ID yet, but it is a straight forward computation now that the gland has been dimensionalized.
Hope this helps you out somewhat.
Principal
As I understand your issue you want to prevent seawater at a depth of 30m from causing a problem with your electronics. Most of the discussion above deals with ways to prevent seawater from entering the shaft seal for a wheel. Have you also considered making your electronics sealed from seawater? How about encapsulating the electronics in some potting compound. At 30m you are likely to get some water in your system. I'd suggest you encapsulate as much of you electronics as possible.
- - -Dennyd
One obvious problem will be with seal cracks developed from relative motion between mating parts. I guess a silicone rubber could be used, but given the environment and usage over time, I doubt it would last long. An alternative could be usage of a gasket, but the draw back here is with the compression requirement to make a seal. I would expect temperature variations, this means thermal expansion and contraction at the joint, hence variation in gasket compression. Perhaps the risk is too great for this type of application.
O-rings are used predominently across multiple industries without significant problems. That is why they are so popular: ease of use, simplicity in design, inexpensive and readly available commercial supply. Of couse the rubber compound itself exhibits memory, the mating part movement argument is immediately addressed. So too is the thermal issue since the rubber itself does not typically change characteristics until 125F or so.
I think either an o-ring is acceptable, perhaps a polypak would be the backup plan.
Principal
