Fixed Beam thermowells
According to ASME PTC 19.3, for steam velocities >300 fps, a fixed beam type thermometer well is recommended. Can anyone provide a sketch or drawing of such a thermowell or simply explain how it differs from a standard tapered well?
RE: Fixed Beam thermowells
Why do you think the recommendation in the ASME standard is flawed?
It is a fixed beam design that extends across a pipe diameter and is supported at each end. it is the worst possible configuration for a temperature measurement, flow induced vibration issues, and thermal stresses.
High velocity designs are available but are rarely needed in the average process application.
PTC 19.3 may be revised, as thermowells satisfying its design criteria have failed. This is apparently the result of it being based on an incomplete and in some respects flawed, stress analysis.
The safest strategy is to use thermowells short enough to avoid flow induced resonance all together.
You might check with http://www.tappi.org/journals, the April 2002 issue. There are related articles in Chemical Engineering Mag. and in the Oil & Gas Journal about that time.
At 300 ft/s, accurate temperature measurement is a problem because of aerodynamic heating, what are you trying to measure?
How does one quantify the amount of aerodynamic heating?
We've covered the velocity ratings with a simple clause linked to PTC 19.3. It is safe for most steam applications but you have to comply with its ratings. Having said that 350 ft/s is a demanding service and you should be considering weld-in thermowells, with full penetration welds and u-dimensions less than an inch or so. To avoid sensor damage associated with the on-set of flow induced resonance you have to reduce the PTC velocity ratings of your well by more than half.
Good luck,
