Support Loads from a Pipeline Curve
I am trying to calculate the support loads resulting from running an above ground pipeline round a large radius curve on guided supports at regular intervals.
Pipe is 8 in, curve radius 153 m, curve angle 15 deg and support spacing 8 m. (Note that the pipe is high pressure GRE.)
The entry and exit to the curve is a straight section, guided and supported as in the curve.
I have searched text books for a solution but noe I have found are suitable.
Any advice would be appreciated.
Dennis Kirk Engineering
www.ozemail.com.au/~denniskb
RE: Support Loads from a Pipeline Curve
OK, this one was too hard and I bought some software to solve it.
The problem is more complicated than I anticipated as I needed to deal with changes in direction (elbows) and out of plane forces.
I had to use 3D structural fram analysis software to deal with it. This problem is now solved.
RGDS
Dennis K-B
