Disposable mini Tube.
I need a "once" only system to put a corrosive fluid through a small diameter steel tube [not greater than 1/4 inch, usually]. The tube must not be re-usable.
Any process, system, cut-off, collapsing or ejection method of rendering the tube useless thereafter will be acceptable.
Will appreciate any ideas.
Tony Mac.
RE: Disposable mini Tube.
How much time after the fluid goes thru the tube do you want the tube to be "gone"? What is the fluid? Temp?
