Need to know Electrical Codes in Australia
Guys,
I'm in the process of putting together some bench scale equipment to be used in Australia. I need to know wiring requirements for small hp. (1/4 hp.) electrical motors and control equipment. Also (as a side bar issue) if you know anything about pressure codes (reactor equipment 0 to 450 psig, once again lab type issues) I will be in debited to you.
Thank you,
Jeff
Thank you,
Jeff
RE: Need to know Electrical Codes in Australia
Failure to refer to AS3008 can result in some unfortunate heating effects and switchgear failure (I speak from our customers' experience here
Cheers!
BigMax
