Excel VBA: Replace$: Sub or Function not defined
I am using Replace$ in some VBA code in Excel without any problem.  I have distributed the file to several testers and for the most part it's ok.
However, one user is getting "Sub or Function not defined" and the Replace$ function is highlighted.
Does anyone know why this is happening?
RE: Excel VBA: Replace$: Sub or Function not defined
What version of Excel (and SP level) is the failing machine running, and how does that compare to all the machines that are running?
I would also check and compare the References between the failing machine and a running machine.
Thanks CC.  You are correct.  The failing workstations (turns out there are more than one) are running with Excel 97.  Replace$ is not supported under this version.
The .xls was created with Excel 2002.
Makes sense.  As I see it, you have two options.  1)  Update everyone to at least 2000, or 2) write you own Replace function inside the workbook.
