Has anyone use Mastertop 300 Anvil Top
I'm just curious if anyone has direct experience with using this product by Master Builders. It is a heavy-duty metallic aggregate topping. It's supposed to have an abrasion resistance that is 8 times that of concrete. My application is for a slab on grade in a steel mill where a loader pushes scrap across it. The current concrete slab lasted about 4-5 years before the loader wore deep ruts in the slab and started to dig out the rebar. It appears to hold up well in the waste industry where a loader pushes garbage across it, but I was hoping someone in the forum might have some experience with this topping.
RE: Has anyone use Mastertop 300 Anvil Top
I've also seen steel plate decking used for a tough floor.
I've seen it used in a trash transfer station slab. We had to remove the first slab section because it didn't hold up the first time. The replacement slab worked and is still in use after 8 years.
Was the first slab section just concrete or did it have the anvil top on it? If it had the anvil top, do you know why it didn't last?
