multibody to assembly
I have a part with multibody -not made by split feature- .
Any solution to make an assembly of this part ?
RE: multibody to assembly
Use "Split Part" and save individual bodies as parts. Then RMB on the "split" feature in the Feature Manager and there you'll find an option to create an Assembly.
--Veera
Thanks floydkv.
But I told you I didn't make multibody with split feature.
I made it at start of modeling by not merging bodies.
That doesn't matter SWscience! I made a practice part before I posted my reply. I made it with 4 circles that were not connecting. So it was a 4 multi-body part. I used split part to save them out as 4 separate parts. then I could use those separate parts in an assembly.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Thanks.
I got it scott.
