nQuadro FX 2000 graphic cards
what's the advantage of these kind of graphic cards in reall work on solidworks.
please tell me clearly.
Is it true that with this graphic card it's possible to use 2 monitor on solidworks , a monitor shows graphic area and another shows feature manager+propertymanager + ... ?
RE: nQuadro FX 2000 graphic cards
As for dual monitors I'm not sure about. I never needed it.
I'm sure someone here can expand on this
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
I saw that testing result you told me.
But there is just acceptable graphic cards for sw , not advantages.
I want to know what I will have if I pas 2000$ for a quadro FX2000 .. is it economical ?
Or I can obtain 90% of maximum performance of a quadro , only by paying 200$ for a geforce . because geforce is acceptable for solidworks in that test result.
Justifing the cost of $2000 for that Quadro should be basised on how complex your parts are (lots of helixes, surfaces, etc). The other reason I would consider that card is also basised on how complicated your assemblies are. If you build complex parts, then your assemblies would be complex too. If your assemblies are extremly large 5000+ parts, then I would also consider a higher end card.
Scott Baugh, CSWP
FAQ731-376
