Dragging dims
Dragging dims
Dragging dims
In SW2004, we should be able to drag a dimension from one view to another and it "jumps" to the correct geometry. I have never got this to work. Has anyone else seen this problem, or have tried it?
RE: Dragging dims
Yes. Hold down the Shift key to move the dim when dragging & dropping ... I usually drop it very close to the feature being referenced.
Holding down the Ctrl key will copy the dim.
from (the City of) Barrie, Ontario.
Support bacteria - they're the only culture some people have
RE: Dragging dims
That worked. Thank you!
your the man!
