SolidWorks Scaling
SolidWorks Scaling
We design and manufacture HDPE containers and blow molds.
We create the product model for the customer then we create a scaled up model for the mold designers.
We have been using SW 2003 for a couple of years with no scaling inssues, but we have switched to SW2004 about a month ago and have ran into two different models with differnt scaling issues.
My questions is has anyone else had problems scaling, if so have you found anything that my fix this problem.
Kevin
Kevin
RE: SolidWorks Scaling
What exactly are the issues? Overscaling, Underscaling, Inconsistent, Doesn't happen, ?????
"Scale1: The scale operation failed to complete as it would have resulted in inconsistent geometry. Try using a different scale value."
We are using a uniform scaling of 1.018"/" about the origin.
I have tried different values with no success.
What I suggest in a case like this, is to open up an old mold that you knew worked ok in a previous version of SolidWorks. Redo the scale feature. Does it still work? If it works ok, then you may know it is your new mold.
Bradley
I have run into this as well. What we found out was that there were edges on the model that were not "perfectly" stitched together. We have this in Pro/E and SolidWorks.
Try this. Save your model as an .X_T or .STP then bring it back into SolidWorks. After you bring it back in, run the diagnosis on it and look for surface problems.
Todd Becker
Kennedy Tool & Die
www.ktdmold.com
That's what I was just about to suggest. We've had the same problem before and the parasolid export/import seems to do the trick. I think the part tends to rebuild during the scaling operation, and a particular feature gets in the way--just a theory.
Besides, the parasolid is a nice, small file that works great when doing more complex cavity operations. This gets important with complex geometry and parting lines, pulls, etc. Although I would expect a blow-mold to be relatively straight-forward.
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
