Joint Efficiency Weld Factor for API-5L PSL-1 and PSL-2
I was wondering if anybody could tell me what the Joint Efficiency for API-5L PSL-1 and PSL-2. Please also give any of speicfications that go along with the particular value.
Thanks.
John
Thanks.
John
RE: Joint Efficiency Weld Factor for API-5L PSL-1 and PSL-2
You will need to look in a design code such as ASME B31.3 or API 31.8, or a regulatory code such as DOT Part 192. The joint efficiency will depend on the type of weld so not all API 5L PSL 1 or PSL 2 pipe will have the same joint efficiency.
