Hole Callout Precision
Is there a way to get an independant # of decimals on the diam. & depth of a hole in a callout (differing decimals = different tolerance on diameter vs. depth)?
RE: Hole Callout Precision
I did the search before I posted and I found that you could not put a different EXPLICIT tolerance on each dimension, but the tolerance I am talking about is implicit based on our drawing standards.
3 decimals = +/- .005
2 decimals = +/- .01
Oh well, I guess that's not possible either.
You can select the hole callout and change the precision in the PM, but you do have to do it for each callout.
