CTOD TESTS
CTOD TESTS
CTOD TESTS
Dear members
i would like to know in detail abt CTOD testing. is there any good link which can direct me there.
Thanks in advance
SK
RE: CTOD TESTS
Try to get hold of a copy of an old book published by Mechanical Engineering Publications Limited London
"A General Introduction to Fracture Mechanics"
ISBN 0 85298 383 2
Good summary of various fracture mechanics tests including CTOD and the application of the results.
RE: CTOD TESTS
To start with you may refer to API 1104 (Line pipe standard)Appendix A. By going through this you would also understand as why this test is called for. Secondly try o get hold of BS  7448. This standard would provide you the method of performing the CTOD.
Good Luck
B.Moorthy
moorthykar@yahoo.com
