Splitting Hole Tables
I'd like to know if it's possible to split a hole table into two parts.  I know this is possible with an (Excel based)BOM in the control properties, but I don't see anything like this for the hole chart. I've got an extra long table showing x's & y's so I'd really appreciate some tips. Thanks.
RE: Splitting Hole Tables
From your query I presume you are using SW2004. You will find the split option when you right mouse click on a cell/row in the Hole Table. Once split you can drag and rearrange
--Veera
