Welding to a codes vessel?
I have a client that has a ASME coded vessel. It had, from the vendor, lugs to attach a platform on. However the platform was not installed and the construction people flame cut the lugs off approximately 2"to 3" from vessel shell. Now the client wants this platform installed. My questions are these: how close to a code vessel shell can I weld without violating the code? ...is it already violated at the 2" and 3"? Should I try just to put a bolt hole thru the existing lugs for this platform? Platform is basically 5ft. Sq and 4"to 6" off vessel shell, for maintenance on instrumentation. THX for the help! ...Mark
RE: Welding to a codes vessel?
The best way to find out is asking your AI. As you would weld on a non-pressure part it would, in my opninion, not affect the stamping, but as I said, the best way to find out is asking your AI.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
The owner should also have information if they are the original owner of record. The main thing that needs to be determined are the new conditions the same as the original design called out.
It is still good advice to involve the AI up front in any work done on any stamped vessel.
