Viewport views with different rotations
How do I have an object in model space with north being to the top of the page, but then have it appear rotated in paper space viewport so that north is rotated 90 degrees?
RE: Viewport views with different rotations
Try
· _dview or
· _mvsetup
Lothar
ADT 2004
ACAD 2002
Since ACAD uses each P-Space vport as if its a complete Model space environment, all you have to do is go to the tab (p-space), click inside the viewport, and use any zoom or rotate-view you want, to get the view you want.
(If I'm doing alot of re-zooming and other work inside the viewport, I like to zoom-w closely around the outside of the vport, to make it almost the whole display, and then re-clicking inside the viewport for my work.)
If you want to convert the image in the vport from the model to a "detail" of the part at the view you've selected, use the soldraw command.
If you later decide to change that detail by altering the zoom of the part for a different look for your detail: in that vport, freeze the 2 layers - hidden and visible - that the detail line work are on, thaw the layer the model(s) is/are on, re-do your zoom/rotate, re-thaw the 2 layers (hidden & visible), ignore that the linework is sitting on top of the model, and re-run the soldraw command. ACAD will clean up the old line-work, create new line work, and re-hide the underlying model, leaving the developed view. Very Cool!
God luck,
C. Fee
I use this all the time to do exactly what you are talking about.
Create your viewport, double click inside of it to go to model space.
Dview command, (Select a couple of objects for reference, don't need them all)
Twist
-90
Then get back into paper space and lock the viewport so it doesn't change when you are zooming.
This way in your model tab north can be up and your viewport north will be to the right.
