old check valve
old check valve
old check valve
I am with a Forensic Engineering Firm. We are investigating a failed check valve. The one in question is a CheckMate CV-200 by Liberty Pumps. I need a similar valve to disassemble. This valve has a yellow sticker and is round with a glued together body. Does anyone have one in stock or know where one is installed. If it is currently installed, arrangements can be made for replacement with a newer model.
Paul Christensen, PE
509-547-2679
pdchristensen@charter.net
