Area moment of inertia
Hey,
I'm trying to calculate the stiffness of a spur gear tooth, but am having a little trouble finding the second moment of inertia (I). Do I need to pull out my calculus book or is there already an equation for it laying around? I've looked in the machinery's handbook without much success.
RE: Area moment of inertia
I=(pi*d^4)/64
This represents a moment of inertia about a line passing through the center (diameter). i.e. the moment of inertia that would be important if you were to grab shaft at both bearings and try to bend it. A picture would be easier.
Not sure if this is what you're after.
Looks like there is some confusion around the terminology I used. Treating the gear tooth as a cantilevered beam, you would use the equation: sigma=Mc/I, or something like that to find the bending stress. The stiffness of the tooth would be: k=3*E*I/L^3. This moment of inertia deals (I think) entirely with the cross-sectional area of the gear tooth profile and not where the center of mass is. I don't know if we are talking about the moment of inertia or not.
Is it sufficient to treat the gear tooth as a trapezoidal beam?
If your considering bending on the profile of the tooth then your formula are correct as the teeth are treated as a cantilevered beam however you need to look for the Lewis Equation which introduces a form factor for the tooth most
design books will have something on this.
Just to clear up some terminology "moment of inertia" is resistance of a body to move against a force so for instance
take a circular disc mounted on a central shaft one would after overcome its "moment of inertia" to get it to rotate about its central shaft. Very often "moment of inertia" is used incorrectly even in text books to describe the resistance of beams to bending loads. The beams resistance to bending loads should correctly be called "second moment of area".
hope this helps
regards
desetfox
Regarding the Lewis Equation...
I was under the impression that the form factor dealt with correcting the bending stress value on the gear tooth, and was separate from the moment of area.
I'm just trying to get the moment of area so I can calculate the stiffness of a pair of gear teeth. I found this equation one online that removes the moment of area completely:
keq=gear_thickness/9*(E1*E2/(E1+E2)) which is the equivalent stiffness between to gear teeth, but I haven't been able to verify that from any reputable source.
Anyone ever seen that formula before? If so, where did it come from?
According to Schaum's Outline series "Machine Design" the second moment of area =
I= b*t^3/(12)
where b = face width
and t is equal to the thickness at a section where a parabola drawn inside the tooth outline is at a tangent with the tooth outline, if you look in the book you will see
what it means.
best I could do in the time I have to spare.
regards desertfox
I'll try to get my hands on that book.
Have a look at this website it may help you.
http://www.mech.uwa.edu.au/DANotes/gears/bending/bending.html
regards desertfox
I'm desperate to keep my model as simple as possible without compromising too much on accuracy. I'd originally used the parallel axis theorem to combine a trapezoid and a rectangular cross-section, which seemed to approximate the tooth decently well. It seems to me (unless I'm reading this wrong) that the geometry factor is actually independent of the geometry of the gear tooth? Or is it valid for one diametral pitch and pressure angle only?
Thanks for the help!
