Soldier Pile Wall with Precast Concrete Facing
Need suggestions on how to attached precast concrete panels to a solider pile retaining wall with temporary timber lagging. The idea would to attach the panels using a type of anchor system that would allow for the installation of a drainage board between the panels and soldier beams.
The piles are spaced 6ft. on center and the wall ranges in height from 10 to 40 feet.
Does anyone have any experience on attaching precast panels to a soldier pile wall? If so, what type of anchoring system was used?
RE: Soldier Pile Wall with Precast Concrete Facing
Where is your site? What will the concrete panels connect to - steel or concrete piles, or the temporary timber ones? A 40 ft high temporary timber wall is a bit scary in many areas...
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora. See FAQ158-922 for recommendations regarding the question, "How Do You Evaluate Fill Settlement Beneath Structures?"
