Titanium - Aluminum Bolted Joint
Hi all, I'm thinking about using titanium bolts for an application I'm designing. The bolts we're looking at are 6A1-4V unplated. They'll be going directly into tapped 6061-T6. I'm not very concerned with the strength of the bolts, they should be more than adaquate as there are a lot of them but I am curious if there are any other issues I should be addressing. I.e. corrosion, the low MOE of titanium etc.
Thanks!!
Thanks!!
RE: Titanium - Aluminum Bolted Joint
Cory
The Ti is being selected for its strength to weight ratio. Basically I have a bolted joint that needs to be as light as possible. In the past, stainless steel fasteners have been used but my calculations show that we can nearly halve the weight with Ti at no cost to strength.
Loading is highly variable but not severe due to the number of fastners. The joint is quite critical but the redundancy is extreme. Normally I would reduce the number of fastners and use the more well known and proven stainless fastners but this is not possible without a redesign. This is not currenly an option.
Environment also varies. The Ti will likely only be used for our own personal applications so I will have a high degree of control over the environment. Temperatures should never exceed 300degF or so. They will get wet from time to time but will never be exposed to moisture (other than humidity) for extended periods of time. They will never be exposed to any corrosives and should be free of any electrical concerns. Anything I missed in there?
Thanks for the quick replys!!! Keep them coming!
John
http://www.beuth.de
Cory
Watch out for your length of thread engagement into the aluminum, you are going to need a significant amount of engagement in the aluminum to be able to develop full strength in the fasteners without having nut strippage as a failure mode. Off hand, not knowing the exact alloys involved, my gut feel is that you will need about 2.5 screw diameters of full thread engagement in the nut to get screw breaage as your failure mode.
Frequent assembly/disassembly is not an issue. Its unlikely that this stuff will ever come apart.
Would a small dab of anti-seize help prevent the galling? Silver plated screws are a good idea, but not really practical for us.
Thanks guys!
I would thoroughly recommend coating the bolts with an aluminum-rich epoxy (eg. NAS4006) to minimize galvanic corrosion, and also lubricating the mating surfaces with MoS2 or graphite upon assembly in order to obtain enough preload without stripping the aluminum thread.
