French standard NF E 25 030
Is anyone familiar with French standard NF E 25 030,
FASTENERS - SCREWED JOINTS - DESIGN, CALCULATION AND ASSEMBLY CONDITIONS
Or, in French, ELEMENTS DE FIXATION - ASSEMBLAGES VISSES - CONCEPTION, CALCUL ET CONDITIONS DE MONTAGE
I have a supplier calculation that cites this as the basis for the calculation, however not all the terms are defined in what I have.
Can someone tell me how the standard defines the terms gamma and lambda?
Lambda seems to be a stiffness ratio, but I don't know what is in th numerator and what is in the denomiantor.
